kovacjr
- Feb 13, 2007
- Lakewood NJ
OK, so researching my initial issue, oil slinging from the front bearing I came up with most likely a clogged return passage. So armed with the 4 page sheet on removal and assembly and my new felt pack I opened her up. Found that there was a bunch of gunk and chips from the previous owner in the groove. See the photo for the port.
I cleaned it all up, installed new capillary wicks and wipers and put beck together with the shims in the same spot and I get a tight spindle. If I tighten the screws on the spreader to open the bearing more then snug I get a looser bearing BUT its still runs hotter then it should. Also I then get .0002" of movement on the spindle. How is that?
First question is I have the indicator mounted to a mag base and on the ways, will there be movement from the headstock on bed that is also being measured? The bearings and spindle are in real good shape, I did not remove the gears to slide the bearings off but can see from the slot and I rotated the bearing to inspect the whole diameter from the slot. I know it was always running warm before, I think from the clogged port as I was always having to refill the pot as it was running out, but its hotter then before and when it stops it comes to a quicker stop than before as its tighter and it hard to spin by hand. I tried backing off the take up nut more up to a half turn making just to made sure ots not an issue. I also shimmed the front bearing with a .001 shim and it was better but I don't get why I'd need to shim it if nothing was changed but the felt and cleaned the port. There is no grit or grime in the bearing seat and the bearing is smooth on the spindle.
I install the caps then the cap bolts, always making sure the spreader it aligned in the slot of the cap. Install the washer and screws loosely then tighten the cap down then snug the screws. I can adjust the screws tighter to loosen the spindle but I don't think its right as its getting opened more than it was before.
Anyone have any ideas what could be happening. I also have the roller bearing on the inside of the rear cap, is there a god replacement for that? I know when I take a heavy cut they whine pretty good. The thrust bearing is the fiber one and in good shape, but I do have a new iolite bronze one but did not pull off and press on the gear
