R
rollmaker
Guest
Are the SBL of any quality whatsoever since Grizzly has been importing them? Personal experiences in a money making environment.
As near as I can tell the lathes SB/Grizzly are now selling are sourced from the same Mfr. in Taiwan that the old, real SB marketed before going belly up. I think the ESOP was a way for the prior owners to get far more money than the company was worth.
AFAIK these were/are serviceable lathes. If you Google the old model numbers I think you'll find tons of info.
I have no idea what a "home gamer" is.I'm a home gamer who's getting into gunsmithing and looking forward to seeing how this lathe handles the job.
I bought a SB 1049F 13x30 lathe and a SB 1042 9 x 42 VS mill this spring when they were more than half off. I picked the mill up at the Springfield store in April and the lathe in May. The mill was a floor model from Grizzly's Pennsylvania store that they closed and got a great discount. The lathe was new in the crate and again less one half their pre sale pricing. So far they have both been trouble free and a big step up from my previous machines. The fit and finish is significantly better than comparable Chinese machines, its easy to see in the showroom where you can make direct comparison. The first thing that was obvious when I drilled into the castings to mount the DRO on the mill was that the castings are denser and finer grained than the Chinese machines I had. I suspect that is why the finish on the ways and table look almost polished and the ways are much harder than my previous machines.
The most surprising part with the lathe was the supplied 3jaw and 4 jaw chucks were very nicely made and seem too be as near as good as the Bison 3 jaw I have. The 3 jaw had been indexed and marked to the spindle for the least runout. With 1" and 2" ground drill rod in the chuck I measured .00014 TIR for the 1" and .00018 TIR on the 2" rod 4" from the chuck. The controls work smoothly, the gears are easy to change and surprisingly quiet. The metric graduations on the cross slide and compound dial are not easy to follow in that one revolution of the cross is 5.08mm and the compound is 2.64mm As mentioned in another thread about the Grizzly SB lathes the degree indicator for the compound is on the circular portion of the compound not on the top of the cross slide and on my lathe the legend stops at 45 degrees but the graduations go to 90 degrees each side of O.
My previous lathes were a Taiwanese ENCO 12 X 36, and 11" VS Rockwell and a 12 X 36 Grizzly G4003 and the SB is better in all respects than the others. I bought the lathe with the intention of adding a VFD and 3ph motor to give more flexible speed ranges.
Notice
