South bend lathe won't change speeds
Results 1 to 3 of 3
    May 2017
    Illinois
    17
    Default South bend lathe won't change speeds
    I get no change in speeds between how and low, on my south bend fourteen. doesn't seem to be electrical. increase and decrease still work just find but just seems to be stuck in low speed settings. Thinking the problem is in the gearbox but before I got though all the trouble of tearing that apart if anyone has anything for me to try I would be glad to give it a shot. thank you.
    Jul 2008
    South Bend, In
    2,406
    120
    192
    The high/low shifter is mechanical.
    Check the shifter first (pin, set screw, etc.)
    Feb 2016
    388
    154
    105
    If that doesn't do it. Maybe some pics of your set up and switch, and what you got going on. Is it using a drum switch ?
