WHOA STOP..
If that is a Leeson 102889.00 there are MAJOR PROBLEMS..
Does it look like this???? :
Leeson Fan and Blower Electric Motor — 1/4 HP | Electric Motors| Northern Tool + Equipment Campaigns&cm_pla=&cm_ite=leeson 102889&mkwid=en5sGDy8H&pcrid=1096244884&mt=e
"This Leeson 115V split-phase motor is designed for commercial duty air over fan motors for air circulators."
It looks like it might be an air over motor... ONLY SUITABLE FOR FAN USE. The fan blades cool the motor.
Next problem.. It is Split Phase, not a capacitor start, which will be needed for a hard starting machine tool like a lathe..........
Sure it will work, for a short while....
There is NO sudden reversing with a single phase motor. (not counting a brushed universal motor Like a hand drill)
Motor will merrily continue to spin the same direction...
Which is a good thing with a threaded spindle.
Nothing like plug reversing a 3 phase lathe, and watching the chuck unscrew, and head directly for your foot.. After making the lathe ways, look just a bit worse..............
Not likely with stock leather belts on a small threaded spindle SB, But possible...
And since ALL 9 inchers were threaded.......
