hepburnman
- Feb 20, 2013
- NJ
I first noticed an oil-level change in the spindle oil cup near the chuck on my SB Heavy 10" lathe. Now that I have removed a little bit of the oil so it doesnt overflow while running I notice now that the level change is due to air bubbles rising up in the cup. I adjusted my shims lately and this is when I noticed these issues. Can't say if this occured before I messed with the shims becuase i did not look this carefully at things. Could something I did when changing shims have affected air vents or something? I did not remove the spindle so my wicks should not have been disturbed. My spindle runs real cool too. What can I do to be sure air vents (if any) are clear? Would I damage anything if I continued to run the lathe without correcting this? Thanks for your responses.
