The other day I ran my 10L on the highest speed for the first time and after about 30 seconds the spindle siezed up, suddenly enough to spin off the chuck. It was surprising because I have been using the lathe for a few months without any problems, but on lower speeds. I thought that it would free up after cooling off but it did not, the only thing I can do to free it is to loosen the front bearing cap.
It is a 40's model with segmented iron bearings, and I'm using Mobil velocite #10 in the spindle. When I set it up a few months ago, the front bearing clearance was at 0.0012". I can still read the same clearance now even though it is siezed. I tried adding a shim, and I was able to get it turning, but the clearance is up to about 0.0030.
Any suggestions?
Any suggestions?
