Ronniet
- Feb 21, 2011
- Amarillo Texas
I have a 11" southbend w/ 1 5/8" X 8 tpi spindle.
I am almost sure the spindle taper is a Southbend Proprietary taper? Not for sure but maybe?
My question is , "is this taper the taper SB uses for its collet adapters? 3C or 5C adapters?"
"And if I were to try to use a faceplate/dog, would I have to make a taper adapter for a MT2 MT3 , Jarno, or what type of center would I use".
"Now if I were to use an adapter/center would it protrude to far forward to allow the dog to use faceplate"?
I know its a lot of questions but am in the process of rebuilding my lathe and want to set up a Faceplate , collet use spindle instead of just a 3 jaw chuck.
I found this article to be interesting.
http://www.sportpilot.info/sp/Use of Accessories Inside the South Bend Head Stock.pdf
This is a link to a picture of the homemade sleeve that came with my lathe, it is rough turned inside and out , it its my spindle taper but protrudes out about 3/4". the insdie of the sleeve fits the MT3 collet in the picture.
sleeve :: MVC-001F_zps8e2cd3d2.jpg picture by rontphoto - Photobucket
any help in what direction I should go is appreciated.
I do not have a thread protector, I guess if I find the correct tooling that allows for collet use , I could make one.
R.
R.
