ronlyke
Cast Iron
- Aug 24, 2008
- Queensbury, NY
I have a double tumbler 9a, with an apparently loose lead screw. When the screw is disengaged, I can grab it and move it left to right--quite a bit of slop. Before I take the gear box & screw off, Is there anything I should look out for? I'm assuming (hoping) it's just a loose nut in there somewhere. I can't find a diagram that shows the lead screw inside the box.
