Tecmec
- Aug 29, 2009
- Connecticut USA
I have read, perhaps on this forum but not sure, that a printer roller is a good item to use between centers to align the tail stock. This is because the roller is a good diameter (about an inch), hardened steel, and has drill centers on each end. I was wondering if this information is dated. I have had the opportunity to strip several printers and found all the paper rollers to be about 3/16" rods with rubber rollers spaced along the rod. The print cartridge traveler is slightly bigger but not by much. Neither have drill centers in the ends. I surmised that perhaps the roller of the old dot matrix printers was as described in the write up I read. Just curious if anyone uses a printer roller as an alignment tool and what kind of device did it come out of.
