Pete Wass
- Apr 10, 2010
- Augusta, Maine & Palm COast, Florida
I recently decided to check the to see if the quill in the tailstock of my 10L ran parallel to the bed ways. I extended the quill to it's max, tightened the lock and ran an indicator back and forward. I found that the rear of the quill was .008" higher than the front. Assuming I could simply shim the front of the castings between the top and base I did so. What I found then was there wasn't a direct correlation between what the indicator read and how thick the shim should be. I now wonder if the rear of the base casting may be higher than the front? How could this be checked?
Pete
Pete
