mikesSB
- Sep 12, 2012
- Michigan, USA
Been working with my new-to-me 1947 South Bend Model B and it appears the tailstock is quite a lot higher (.050 plus or minus a couple thousandths) than the axis of the headstock. Previous owner didn't knw much about this and only tried to use it a couple times in the 10 plus years he owned it...
I centered a cylindrical part in the 4 jaw chuck with a known center point visible and then chuckd up a new dead centerpoint in the tailstock.. Also tried it with a 3 jaw chuck as well as with a drill chuck and a small drill bit in the tailstock...several combos ...same thing.
I know a lot has been written on this subject but am kinda stuck for a good answer. The lathe is a older green model and the tailstock is painted grey. I would assume the tailstock is newer than the lathe and it would be great if it might be as simple as swapping out the tailstock... Everything looks clean...I did remove the headstock when moving the lathe this fall and re-installed it carefully checking the ways to ensure no dirt or residue was on them...Didn't see any shims...Cant see any dirt or matter on the bottom of the tailstock either...
I can post a couple pics later tomorrow as perhaps this will help.
