Just picked up a 9" model A Lathe. Runs well and tolerances close enough for the work I need to do. One issue however is the Tailstock clamp does not appear wide enough. It will literally drop right thru the Ways. The clamp that came with the lathe has the following part number "56N3" stamped on it. It is 2 21/64" at its widest, 2" inside groove to inside groove and 2 1/16" long.
I can sort of get it to work if I twist the clamp so it catches edge to edge diagonally.
I guess the question is, is this the right part? If not anyone know the correct part number so I can start looking for a replacement?
Thanks for any help.
Mike
