greaseape
- Mar 10, 2010
- Toledo, OH
Good morning everyone; I am the owner of a South Bend heavy 10. The lathe is now in working order and I have been using it.
It came with a US to Metric transposing gear and a full set of gears to cut metric threads and I have done so a couple of times.
successfully.
What is not clear however, is what stud, idle and screw gears to use to cut US Standard threads. Can someone tell me how many
teeth each of these gears has, in order to cut standard threads, or where to find such information?
You can contact me directly if you want. Let me know what you need.
Thank you very much, Chipper.
P.S. I forgot to mention that the lathe is equipped with a 2 tumblers gear box.
successfully.
