Hello,
I recently bought a SB 10L with the treaded spindle.
The first time I needed to remove the chuck I was clueless on how to get it off. I ended up locking up the spindle in the back gear and lightly tapping a large crescent wrench on one of the jaws with a rubber mallet. It did loosen, luckily I did not chip or damage the bull gear etc. or hurt the chuck (I had sense enough to tighten the jaws in).
I bought the book "How to run a Lathe" and it showed using a wood block and rotating the spindle (in back gear) by hand to remove the chuck.
I tried this and found the block kept slipping out so I made a wood block fixture and that cured the block slipping. I've also found that 99% of the time I cannot loosen the chuck unless I use a strap wrench on spindle pulley (see pics).
Is there any chance I will damage the bull gear or chuck using this setup? Are there any tips or a better method anyone can share with me? Gary
