mikesSB
- Sep 12, 2012
- Michigan, USA
Pretty cold her in Michigan... 20's-30's and even colder soon.
Unfortunately there is no heat in my detached garage so it will be almost as cold in the garage as outside. Is is too cold for proper oil transfer in bearing surfaces to run a lathe in this weather? Would like to try it out and do a couple small projects if possible. I piced it up earlier this fall and haven't run it except for 30 seconds or so to see if it's set up ok. The spindle turns nice and smooth and the countershaft set up seems like it is working fine.
On my way out later this afternoon to Production Tool in Redford, MI to pick up some way and spindle oil...
PS- Production Tool has a sale on either way or spindle oil (can't remember which) at around $20 per gallon.
