A QCTP can be an advantage in some cases. I have a 9 Jr and I continue to use the lantern tool post for it. I have a 9-C and I still use its lantern tool post as well. My Heavy 10 came with a lantern post (which I still have) but I purchased a Phase II wedge-type QCTP for it. My son has a 9-A at his business and it has a Phase II QCTP.
The QCTP is more rigid in supporting the tools than the lantern style holders and you can use larger square bits. If you do a lot of repetitive operations, the QCTP can save you some time. For example if you need to turn a piece to diameter, knurl it, and part it off you can set each tool block to the correct height and then just change blocks for each operation. The wedge type QCTP will hold tool position very accurately if you make sure you keep the mating surfaces clean.
On a 9" lathe, I find the QCTP to be in the way fairly often and it limits your ability to "get in close" for some operations. You'll find it banging into the tailstock quite often, for example. This is less of a problem on the bigger lathes.
I'd say that you should consider getting one if you think that's what you want but DO NOT get rid of the lantern holders because, especially on a 9" lathe, you will find cases where you just about have to use the lantern holder in order to be able to get the tools in where they need to be.
Avoid the bargain price piston-type QCTP's because they are not as repeatable for tool location as the wedge-type. You can always hope for a bargain on an Aloris but I've been quite happy with my Phase II equipment.
