Halligan
- Oct 6, 2011
- Massachusetts
I think I may have asked about this a while back I'm not sure. Anyway I've been wondering what machine this was for for a while and I forgot all about it untill I went to usae my collets today and saw it again. I picked up this set of 3c collets with these fixtures a while ago. All the collets are southbend and in the box with them was a southbend pamphlet so I assume these fixtures are from Southbend too. It is obviously some sort of nosepiece for the collets, but it's huge. If you have a machine that big why would you be using 3c collets? The big one has a tapered shank. The large end is about 1.652 and the small end 1.546. The taperlength is about 3.50. I can't match this taper to anything. The smaller fixture has a straight shank. The nut on the outside is tapered to close the hole like a collet. The inside of it is huge and won't fit the collets. I tried the collet nosepiece for my lathe but that won't fit in there either.
The Set:
Nosepiece?
Other Piece:
It's huge:
The Set:
Nosepiece?
Other Piece:
It's huge:
