northeastconfederate
Cast Iron
- Jan 25, 2005
- New Egypt, NJ
I've been using the boring bar a bit lateley, and
have been astounded at the amount of deflection inherent in it. Or maybe it's the work deflecting. The work is a fairly large socket (finished inside diameter is 2.055"). I'm enlarging the 4 "teeth" on a spanner socket, so the teeth "hit" the cutting bit on their way by it. the bit is as close to the tool post as I can get it to minimize deflection (post is an import knock-off of an Aloris), so there's about 5" of the bar (which is substantial, guessing 5/8" dia) extending ot the other side of the tool post. This end of the bar jumps at LEAST 1/16" each time the teeth of the socket hit the cutteing bit. without changing the cross feed, just making the same cut again, it takes another 3 or so thou! Any way to calculate and compensate for this, or just go slowly and carefully with very light cuts?
