Toolpost for a 1951 SB13
Results 1 to 15 of 15
    Feb 2017
    Ohio
    6
    Default Toolpost for a 1951 SB13
    So I bought a 1951 Southbend 13" lathe, and it did not come with a tool holder. I have gone to a local store and got a catalog, but none of them fit the dimensions for my lathe. The manufacturer part is ce2450t, and im looking for one, but i really want a quick change tool post. Ideas?
    Jul 2013
    Chicago
    134
    9
    34
    Try an Aloris BXA or equivalent. I think a CXA will be a bit large for your lathe. You will probably have to make, or modify, the nut that goes in the compound. Do you have a mill, or access to one?
    Best regards,
    Marc
    Aug 2013
    NY
    2,302
    981
    791
    BXA. I have an AXA with a previous-owner-made 1/2" riser. It works just fine.
    Sent from my XT1053 using Tapatalk
    Feb 2017
    Ohio
    6
    Negative, no mill
    Feb 2017
    Ohio
    6
    Riser... so a regular AXA, with a .40" riser comnected to the bottom? How does it stay put in the channel?
    Jun 2006
    Seattle, WA
    930
    80
    539
    You don't need a mill. Many a QCTP nut have been sized with nothing more than a hacksaw and a file.
    Feb 2017
    Ohio
    6
    This is my first lathe, and Im pretty sure you are speaking greekt
    May 2012
    Indiana
    890
    160
    323
    Quote Originally Posted by steventenney View Post
    Not Greekt. Wawoodman is from the left Washington. I will translate for you: 7:7(/(,86)9;4$!?$;;;.
    Seriously wawoodman means the compound t-slot can be nothing more than a length of bar with a tapped hole in it. A BXA toolpost will come with an oversized blank to be machined to fit your lathe.
    Make first the bar with tapped hole and mount your post. Then use that arrangement to machine the BXA blank using a 4 jaw chuck to face off and drill/tap to size.
    Feb 2017
    Ohio
    6
    Ok, so make my own part for the bottom slot with a hole in it to allow the quick change post to be mounted to it. As long as it will fit in the channel, i should be good.
    May 2012
    Indiana
    890
    160
    323
    Make it as long as the tool block is wide and as thick as will fit in the slot. Leave a little clearance so it slides in easily but make sure it seats fully when tightened.
    Does someone have a photo that would help explain?
  11. #11
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    I have machined many nuts for different T slots with a lathe. Easy!
  12. #12
    Feb 2008
    newark DE USA
    1,040
    84
    You can't have too many ways to position the cutting tool. I have three lanterns,two tool blocks and a quick change post for my SBL 13. They also work on my regal 13 and I have another block with it.
  13. #13
    Mar 2010
    Utah
    648
    44
    36
    img_1402.jpg photo of the T slot for tool post.
  14. #14
    Feb 2017
    Ohio
    6
    Quote Originally Posted by packrat2 View Post
    Awesome! I will have someone make one for me! I dont have a mill
  15. #15
    Feb 2014
    121
    9
    You could make a round one right on the lathe that looks just like the bottom of the lantern tool post where it slides in the slot.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
