chip's
Cast Iron
- Sep 2, 2002
- Idaho, USA
I have tried everything I can think of to quiet the left end gears on my 16" lathe. I have changed the direction of the gears( on the reversing tumbler.) The gears including the spindle gear all look fine. Open gear lube helps some up until about the 300 rpm range. The gears get much nosier at 600 and 900 ranges. With the banjo down the gears are less noisy. Of course the more of the gear train engaged for feeds the more noise.
Is there anything that can be done to quiet the gear train down some? The backlash looks about right on gears that are able to be adjusted.
What, if there is such a thing is a normal amount of noise? Thanks for any help!!
