Halligan
- Oct 6, 2011
- Massachusetts
So after seeing iwananew10k's video with the collars I wanted to do the two collar test found in HTRAL for tailstock alignment and compare it to that other method I showed. After levelling my bed and readjusting my tailstock by my original method I made and mounted a two collar bar between centers and took a cut. The bar is 12" long and the collars spaced two inches on center from the ends, I got a deviation of less than .001 between the headstock and tailstock collars the tailstock being larger. I tweaked the tailstock towards me about .001 according to my dial indicator and repeated the test with the results being both collars pretty much exactly the same or within a few tenths. The video can be found on my channel Here:
Two Collar Lathe Alignment Test - YouTube
Part 1- Making the bar
Part 2- Making the test cut @ 15:15
Part 3- Results @ 18:38
