Eric Commarato
- Apr 29, 2003
- Madison, MS, USA
I've decided to replace the cone pulley shaft ony SB 9" horizontal drive. The cast iron journals seem o.k. But the 7/8" shaft is pretty scored on the large drive pulley side. What type of shaft material should I use? Drill Rod might be too hard, 304 stainless? Some other type of stainless? Also I will need to make a new tapered hole for the pulley tapered pin, or should I just use a hardened split spring pin?
Thanks, Eric
Thanks, Eric
