Cabbagestack
- Jul 16, 2016
I have a leveling foot from a SB lathe, I imagine that it's from a 9 UMD workshop or a 10K, though I have no way of being able to tell. I have attached photos of it. It has "403NK1" cast in the top piece and "402NK1" cast into the underside; you can barely make it out in the photos below, but they are there.
Also I have attached a photo of my SB 9A. It is very similar to Paula's (same Cat#).
Question: offhand, can anyone tell me if this type of foot can be adapted to a mid-40's SB 644Z 9A, like mine pictured below?
What I'm hoping for is it will be a direct replacement without a bunch of machining or fabrication. Wishful thinking, maybe. But even so I'd like to make it work, as I like the three point leveling concept. Going to build a new bench for the lathe, with the three point, in mind (if this works).
Incidentally, always have been bothered by the lack of rigidity of that 4x4 - 2x6 bench. That's gotta go! Might have been good enough for one's father or grandfather, but I simply can't have that going on. I need to get a fairly robust steel bench.
Thanks!
Thanks!
