datmony
- Dec 30, 2013
- Duvall, WA
I just finished the rebuild of my 10k last weekend and my VFD just showed up yesterday, a Teco, N3-203-CS-U. For those of you who have set your lathes up with VFD, what are the pros and cons of wiring the stock switch into things?
It seems like it would be a simpler installation to simply just wire the motor to the VFD and wire the VFD to the single phase power and just skip the manual forward/reverse switch on the lathe and use the forward reverse functions off of the VFD instead. Am I missing something there?
For those of you that did wire in the switch.... what made you do that? Is there some benefit of having it run through the physical switch versus the VFD itself that I am missing?
Thanks in advance!!
Thanks in advance!!
