Sachmanram
Stainless
- Jan 17, 2011
- New Brunswick, Canada
I answered an ad in the local KIJIJI ( kinda like craigslist ) on the weekend, and ended up buying this lathe.
It's a little worse for wear, but I think that it will clean up nicely. The sad thing about this lathe, is that at some point in time, someone removed every single brass placard and also the brass/ bronze tumbler-reverse handle, so I am guessing on the model. It looks to be a 15" swing.
Here's a pic of the serial # ...
From what I can figure out, it was built in 1943 and served in the U.S. Navy. That's interesting.
Here's the lathe in my driveway before bringing it into the shop...
The lathe was loaded onto the trailer with a good sized Kubota tractor, which was all it could do to lift it high enough. On my end, all I have is a 2 ton engine hoist, so I ended up dismantling it, piece by piece and onto the floor.
Here's a series of pics of that process...
The process took two hours to complete, but it went smoothly. Now, the real work begins.... It's missing a few bits and pieces, but I should be able to find them.
Brian
Oh, and some of you will notice that the compound is something that was home made, but I have the original (I hope) compound in the truck. It is suspicious that someone would replace it with a home made one...
Brian
