earlyworm1
- Nov 24, 2005
- Joliet, Il
I have a early thirties lathe. It is a Catalog #405-Z Serial #54123. It is very limited in what I can do. I am trying to cut 20 TPI I have a 24 tooth gear on the spindle abd 60 tooth gear on the screw gear per plate on the gear cover Any gear can be used on the idle gear but the largest I have is 105 teeth gear and it will not fill the space between the 24 tooth spindle and the 60 footh screw gears. do they make gears larger than 105 teeth?
