What lubricant to use on chuck components?
Results 1 to 10 of 10
    Aug 2017
    Ohio
    63
    16
    Default What lubricant to use on chuck components?
    I have a 3 jaw and a 4 jaw that I took apart for general cleaning and derusting. Im wondering what type of oil you should use on the internal components, such as the scroll for the 3 jaw and the jaw screws for the 4 jaw. Would way oil be appropriate? It seems like youd want something a bit heavier.
    As an aside, i know youre not supposed to use grease in chucks, but my 3 jaw (an old union manufacturing chuck) had grease in some pockets around the outer edge, not on any of the moving components. It looks like its purpose might have been to collect and hold any stray chips that did make it into the chuck-thoughts on this? It seems like a clever idea, and I cant imagine what else the grease would have been for
    Aug 2007
    Wisconsin
    1,932
    856
    790
    We use Mobil XHP 221 for pretty much everything in our shop including our CNC lathe chucks.
  3. Likes B-Mathews liked this post
    Mar 2016
    New Jersey
    901
    16
    174
    whatever you use on it, the first time you go to use it set the machine to max speed and put a cardboard box large enough to sit on the ways and go over the chuck before turning it on. The excess oil will sling out into the box rather than all over you.
    Sep 2016
    Missouri
    26
    I have to agree with the Hot Rolled. I guess I over greased the spindle of my drill press. It has been slinging grease at me. Just two more pumps of the grease gun will be better. Ha
    Sep 2010
    moscow,ohio
    4,394
    443
    1270
    One of the few places I ever used grease.
    I used motor assembly lube...common in little tubes as lubriplate 105
    Sep 2004
    RSA
    1,127
    291
    196
    Quote Originally Posted by Domodude17 View Post
    A dry assembly paste made by mixing a bit of linseed oil with MOS2 5 micron until it's like a hard(ish) cake. Dissolve in kerosene and apply with brush. Let dry and wipe off but not too energetically. Alternatively Schunk sells what they think it's best.
    Jun 2006
    Near Seattle
    4,264
    2222
    1003
    Uh, note that some chucks (notably schunks) explicitly require a grease, and chuck-ease is a grease specifically made for chucks...
  9. #8
    Mar 2016
    New Jersey
    901
    16
    174
    Quote Originally Posted by mllud22 View Post
    I figured that trick out after putting too much on my 3 jaw. First time I turned the thing on I had a stripe of oil from eyebrows to belly button.
    I've used both way oil and NLGI-0 grease. The oil seems to have less problems with chips getting stuck.
  10. #9
    Sep 2016
    Missouri
    26
    I have an old 21 inch Union chuck on my Cincinnati lathe. It has grease fittings on the back of the chuck right behind the clamps that hold the screw in place. I am going to grease that but wipe off Any excess and use a good oil on the screw. That's a tough area to try to brush chips out.
  11. #10
    Aug 2017
    Ohio
    63
    16
    On my 3 jaw, the back portion with the gears is sealed so I used grease in there. The front of the scroll and jaws got way oil. The screws on the 4 jaw got way oil as well
  12. Likes mllud22 liked this post
