Hi Gary and All,
South bend Lathes use three types of oil. The lubrication chart refers to them as A, B and C. These oils were rated by the old Saybolt viscosity system (Saybolt Universal Seconds {SUS}). Most oils today are rated by SAE or ISO systems. This is how it breaks down:
A - 100 SUS @ 100 Deg. F - ISO 22,
B - 150 to 240 SUS @ 100 Deg. F - ISO 32 to 50 or SAE 10 to 20 (20 is the better choice),
C - 250 to 500 SUS @ 100 Deg. F - ISO 55 to 100 or SAE 20 to 30 (30 is the better choice).
South Bend Lathes recommends NOT using motor oils. They contain additives that can prove harmful to the machine over the long run. Use only high grade machine oils. I use Mobil Oils as follows:
A - Mobil Velocite Spindle Oil No. 10,
B - Mobil DTE Hydraulic Oil 25 or DTE Machine/Turbine Medium Heavy,
C - Mobil Vactra Way Oil No. 2.
Mobil machine oils can be ordered from McMaster-Carr or MSC or a number of other good supply houses. Of course, there are other equivalents made by other oil companies.
Older lathes, with oil cups on top of the bearing caps have the felt wicks running in a slot in the top of the bearing. Lathe with oil cups located in the headstock below the centerline of the spindle have spring loaded felt wicks that ride under the spindle. The slot in the top of the bearing on this arrangement are for the bearing expanders. These expanders do have a piece on felt in there but it is the wick under the spindle that supplies oil to the bearings.
The best way to clean the wicks is to take then out and soak them in paint thinner. But it requires the removal of the spindle. Barring that, one can remove the oil cups and flush out the system using the solvent of your choice. Just let it drain a good long time before reinstalling the oil cups and putting the lathe to use (after oiling, of course).
One should flush out the apron too while your at it. Anyway, enough for now.
I hope this information is helpful.
-Blue Chips-
Webb
[This message has been edited by Webb Wyman (edited 02-17-2004).]
