Ooooh..... I have a 9 Jr and I've never entertained the idea of fitting a QC gearbox to it. While the 9Jr and the Heavy 10 have a similar bed configuration, there's a lot more.....a whole lot more stuff to consider.
First you say yours is a change gear lathe. That means that there is no provision for power cross-feed or longitudinal feed in the apron of your carriage. Given that, I'd ask what advantage you think you'll have by going to the QC gearbox if you can't use power cross-feed nor the power carriage longitudinal feed. And, you don't have a lead screw with the slot milled in it to drive the "works" inside the apron used for the power feeds. You'd have to mill the slot in yours but it would still be the wrong length for a QC gearbox. Or perhaps you could find another lead screw with the slot in it and get it to fit your lathe with the QC gearbox on it.
As if that were not enough, I seriously doubt....but don't know for sure.....that there are drilled holes in your bed that you can use to attach the QC gearbox to the bed.
If you want a power feed lathe, then that's what you should go buy. Changing yours over is going to be a nasty project with not very good chances for success.
There is nothing you can't do with your change gear lathe that you could do with the QC gearbox addition. It may take you longer but you can do it.
I find the 9 Jr. has its own charm the way it is. I'd hate to tear it up with a project like you're suggesting.
