I have a old SB Lathe cat# CLC 155C sn# 8090HKX 12 finally getting around to wiring it up
motor tag only list High voltage or Low voltage and says its 3 phase
it does not tell me what voltage or amperage it should take
the wires on the motor are connected together for high voltage
I ran 3 phase 480v on 20 amp breaker to a 10amp fused disconnect switch
started it ran correct forward and reverse direction then heated up one of
the 10amp fuses change out and replaced with 15amp fuses thinking it
needed more power but then it tripped 20 amp breaker
it has a Furnace J2 drum switch wired correctly it use to run when I bought it
how much amperage and voltage do these motor require to run ?
