The advertised tolerances for Nook rolled thread leadscrews is .0003"/inch +/-.
This may seem "huge" but how many of us use our SB's to cut other leadscrews?
How many of us have original leadscrews with that much wear in some sections?
If you buy any leadscrew stock and plane a slot in it, it will warp. If the concern is 10ths, how much does the length change when it is straightened?
When I replaned a 54" bed and put it under my formerly 4' 10K I just went with a Roton rolled thread leadscrew and made the spliced on end for the gearbox here. It will be necessary at some point to make a cross-slide screw for the same lathe. I'm pretty comfortable that given the aprox 4" of useful cross travel, when making that screw, a total error of up to .0014" in that distance will never be an issue in use. First, the error is probably not completely uni-directional and may be less cumulatively. Second, I don't think I've ever seen a 9" or 10K that did not have more than that error due to differential wear of the cross slide screw.
Beyond that, a 10K will not be my choice for making other leadscrews, or screws for diffraction gratings or ruling engines. For any other fits or typical bolts, .0003"/inch will be within my needs if it is even that bad.
I did send Roton an email requesting info on their tolerances for 3/4"-8 rolled thread leadscrew, and what the cumulative tolerance is over 3'. Maybe they will reply next week. At some later date when time permits, I'll get out the gage blocks & .0001" indicators and see what mine actually does as installed.
SB leadscrews were apparently made exceptionally well. None other than late PM'r Jim Kizales (whose career started with NBS) said SB precision leadscrews made them the go-to machines for some close ops there. Out in the field of us regular users, though, the worn leadscrews, not to mention the rest of the lathe, probably fall a good bit shorter. SB made really good & accuraate parts and assemblies, but they tended to use soft easy to machine materials that wear quickly. I'll worry about nanometer tolerances on a leadscrew if time ever permits rebuild on one of the Hardinge TL's here. Until then, my SB is back in sound operating condition quickly and inexpensively, soldiering on doing everyday tasks it is so practical for.
smt
