WTB: heavy 10 cross feed bushing for dial
Results 1 to 13 of 13
    Dec 2011
    Nebraska
    95
    5
    Default WTB: heavy 10 cross feed bushing for dial
    Looking for this cross feed bushing for a heavy 10 small dial.
    Apr 2010
    Wisconsin
    5,227
    3894
    2886
    That happened to me about 25 years ago. I feel your pain. If you are not able to find one ( unlikely, but possible ), lock your cross slide, and use the compound for adjustments to the tool in effort to turn a new one. The original was CI, but it really does not need to be. Good luck.
    Dec 2004
    Indiana
    1,344
    75
    51
    In your photo I can't read the scale. Measure the left end bushing length, of the two versions one is shorter, 21/32 one is longer 25/32. the right side to the thread ends are basically the same length. I have both, but they both have somewhat chewed up threads.
    Steve
    Dec 2011
    Nebraska
    95
    5
    Got one from MR. Wells, all shimmed up and back up running.
  5. Likes Zahnrad Kopf, intrepid, thomasutley liked this post
    May 2017
    BELGIUM
    I find myself in the same situation. The part seems to have broken because the oiler grub screw above blocked it. I'm looking for the version with the 25/32 long bushing.
    The machine is a small dial SB heavy 10 with metric graduations I recently acquired together with a Van Norman 6.
    Nov 2015
    29
    Mine has been repaired sometime in the past and I think I may attempt to make a new one. Does anybody have a drawing or know what the threads are? Mine is a large dial.
    Sep 2010
    moscow,ohio
    4,399
    444
    1271
    thread is 25/32" x 16tpi
    crappy drawing in this thread-(ignore all the craziness, I was just having fun with what was on hand)
    wide 9 heavy 10 cross feed repair/replace
  9. Likes traditional-tools liked this post
  10. #8
    Nov 2015
    29
    Thanks. I will study up. Mine was broken and put back together. It works but not quite right.
  11. #9
    Dec 2011
    Nebraska
    95
    5
    The reason I broke mine was the oil holes didn't line up and I over tightened it and the threads were ruff from the oil screw digging it to the threads. On my replacement I added some shims so the oil holes would line up.
  12. #10
    Sep 2010
    moscow,ohio
    4,399
    444
    1271
    You do not want the holes to line up.
    Think about the design...the hole in the bushing is in a relief groove, once that bushing is screwed into the saddle it becomes a reservoir.
    If the holes lined up not only would debris be prone to fall straight down onto the screw shaft but the reservoir would be defeated too.
    IMO the *ideal* position for the bushing hole to end up is *somewhere* between the 4 and 8 o'clock positions since debris would tend to wash past the hole but still retain the reservoir function...but that's just me.
  13. #11
    Oct 2013
    Allentown, PA
    513
    43
    78
    I have a spare of that part for the little dial machines. PM me if interested
  14. #12
    Nov 2015
    29
    Mine is a large dial. :/
  15. #13
    Oct 2015
    Virginia
    265
    10
    44
    Oops, wrong part, nevermind.
