plazamachinery.com has threded tubes you can use to make your own.
129. New tube replacement for 9” south bend. Threaded, better steel than original. Minor machine work to fit your existing draw tube assembly. We could not do the final machining because SB had 2 different ones. This will work for both. Made in USA, $85.00 (solves the worn thread problem)
Steve
