racer55
- Mar 9, 2009
- Canada Scugog Island Ontario
I was wondering how critical the 10% variance is for motor voltage.
I have a 2 hp 550v mill and a 2.5 hp 550v lathe I would like to run.
I have built a 7.5 hp rotary phase converter based on plans found here and on the web and have balanced it to the FW specs.
it is a 240v converter with B being the wild leg.
AB=258v
BC=258v
AC=238v (line) so my generated legs are exactly line*1.08.
now for the rest of my question.
I bought a 6 kva autotransformer with legs to go from 240v-600v.
so I now have approxamatly 630v on the high legs and 598v on the line legs.
this is about 25v outside the 605v to stay within the 10%-will this do harm?
I did try drilling a hole with the mill to load it down but the voltages only slightly dropped.
amps are 1.2,.8,.7 for the mill at idle fla is 2a.
all opinions welcomed
thanx
AB=258v
BC=258v
thanx
