Ryanjax
- Apr 24, 2010
- Jacksonville, FL
I'm in the planning/procurement stage for my 15hp RPC build. So far the list of items that I have is:
Panel 16x20x8 Is this a good size?
Circuit Breaker 60A 2 pole
Contactor (K1)240V/24v 75 Amp 3 Pole with auxillary contacts
Potential relay (K2) Supco 9066
Terminal Block
Start Caps ~1050uF @70uF/HP
Run Caps ~225uF @15uF/HP
Control Xformer 50VA 240V/24V
Start Switch NO
Stop Switch NC
E-stop Switch
Volt/Amp Meters X3 (Do I need these)
Din Rail
How does this list look? Also, not completely sure how to wire the potential relay.
Does my schematic look correct?
RPC.pdf - Google Drive
Terminal Block
Start Switch NO
Stop Switch NC
E-stop Switch
Din Rail
