rambo2_981
- Aug 5, 2015
I was told an older woodworking machine that I'm looking at is 'single' phase, "208v with 2 hots and an edison tap". I've not heard that before. Will it run off single phase, 240V that we're all familiar with?
I have not a clue what an edison tap is unless he meant neutral. There is 120 volts between any of the 3 phases of 208 and neutral. There is 208 between any two phases of a 3 phase feed. 240 volt devices running on 208 have reduced power. I don't know if 208 devices can tolerate 240. Some are made to handle either and some are not. If you are sure it is a single phase 208 device, there is a simple solution. They make 208 to 240 autoformers. You can use it either way to step up or down. Just make sure it has the proper current rating for the device.I was told an older woodworking machine that I'm looking at is 'single' phase, "208v with 2 hots and an edison tap". I've not heard that before. Will it run off single phase, 240V that we're all familiar with?
That is describing a 240 feed and a neutral which is what is fed to virtually all private homes. It discusses why it is used. Since I am not a power distribution engineer I just deal with what I have to work with and let them worry about supplying it. The OP was discussing a 208 volt three phase feed which is supplied to industrial users. It is not the split phase in your link.
Sent from my SM-G900V using Tapatalk
Because 208 is only supplied as 3 phase power. Nobody is supplied with just two of the three legs that yields the single phase 208 the OP is talking about. That is as improbable as your power company supplying you with only one leg of 240 and a neutral for 120 only service. They do not go to the trouble of distributing 3 phase to feed only 2/3 of it to any customer. This is what is normally distributed to commercial and industrial customers.Pardon, but the OP specifically said single phase. Where did three phase arrive in his query?
As for "Edison tap", all I can make of that is the neutral..... The guy did invent the split voltage system.
A 208V motor, without further info, would NOT be expected to run on 240 in my world. It might do, but likely would be drawing excess current due to saturation.
OK, please the OP forgive me for the tangent, but...
I have lived in a condominium from 1989 through 1992.
Then, after an intermediate move, went to another condo in 1997.
The first condo had 110/192 power, while the other had 120/240.
Can you please describe how Joe Schmuck is supposed to explain what he might need for appliances to the local Home Depot Specialist?
Seriously? The difference between 208 and 240 is less than 16% and you do not expect an AC induction motor to function within that criteria?
NO I DO NOT.
UL voltage limits are 10% above and below MARKED voltage.
The 208 can be ...
That would be my guess... they want a neutral for 120V control voltage without having to supply a control transformer.
Dennis
That actually does make sense. Essentially they're using the motor windings as an autotransformer to give a 1/2 voltage tap.
Notice
