Heavymetal70
- Jan 5, 2018
I built an RPC using a 20hp or 25hp( have to check ) 1750rpm electric motor and capacitor bank. The problem I have is that I run several machines off of this unit that vary greatly in hp and load. If I run it balanced for say a 1 1/2hp drill press, it's not balanced for the 15hp planer. My question is, can I use relays to bring in more caps based on the machine I need. If I balance it for the planer, and then let it idle, the CEMF makes the motor hum loudly and my idle current is way too high.
