rjibosh
Hot Rolled
- Jul 22, 2003
- Los Angeles
I have a Carter/Regent 1 hp AC/DC Universal motor with a Minarik DC drive (23001A). The drive puts out 0 to 75 VDC. The current flows thru the armature then thru the field to form a complete circuit such that the armature and the field are in series. In order to reverse this motor the armature leads have to be reversed so that current starts at the opposite brush and then procedes in series thru the armature and on thru the field. This particular drive has a polarity reversing switch. However simply reversing the polarity seems to make no difference to the motor. I runs in the same direction and has the same variable speed function regardless of polarity. I'm setting this motor up as a spindle drive and will use a contactor wired tol create the proper circuits to reverse the motor. So I have two questions. First why does it not matter what the polarity is? Second, is there any advantage or disadvantage to using one or the other polarity?
Rick
Rick
