George Andreasen
Stainless
- Feb 11, 2007
- Alturas, California
I've installed a TECO FM50 to run the 2hp motor on my Hendey lathe, and frankly I'm impressed. Now I have to install permanent wiring and a 220 1ph plug rather than trail the cord across the floor to the present outlet. I have existing 220 1ph at the new location for my Hendey shaper and would never run THAT motor while using the lathe, but I'm concerned what would happen IF the shaper were started by mistake (both plugged in, only one running). Perhaps this is a bad idea and I should run a new dedicated circuit?
