Albert Hofmann
- May 6, 2017
Hi, I'm actually not a Grumpy Old Machinist, but rather a CNC router guy. You guys seem to really know your way around 3 phase power, so hopefully you'll cut me some slack.
I just moved into an older building with 240V power and I'm trying to get my machines hooked up (CNC routers,both require 480 volts). The majority of electricians haven't returned my calls, one of them didn't want to work on an older high leg system, and the one who returns my calls and actually seems to want to do work and get money for it has proposed reverse feeding a stepdown transformer and running my machines with ungrounded delta.
I told him I feared for the safety of my VFDs, and he didn't seem to know a lot about VFDs.
Here are a few questions on my mind:
1. Is there any advantage to giving each machine it's own transformer? It seems like feeding both off of one is the most economical solution.
2. Is it worth paying the extra money for a transformer with 240 delta on the low side and 480 wye on the high side? Obviously this would have to be purchased new, so cost would be about double that of a used delta/delta.
3. If I do run 480V ungrounded delta to the machines, do I need some kind of additional ground fault protection? I read what motion guru wrote about the wholesale destruction of VFDs on an ungrounded delta system, specifically about the problems with MOVs.
Thanks for any help and advice.
