jermfab
Cast Iron
- Jul 25, 2013
- atlanta, ga
I was recently given four HID hi bay light fixtures and three boxes of bulbs(!!!) for the fixtures. Problem is my building has only 208/110 three-phase power. These are single phase fixtures so the third leg doesn't matter. I just finished paying for the 600 amp 208 service so I'm not gonna rewire for these lights, nor does it make financial sense to even purchase a transformer.
Can I run these on 208 volts? Readings between legs runs closer to 215 volts.
These fixtures and bulbs were a gift so I'm okay with reduced efficiency, but I will have to run a circuit for the lights and don't want to incur those costs if this is a bad idea overall.
Will I run the risk of overheating the transformers in the fixtures?
Are there any other potential dangers I'm not thinking about?
I'm gonna bench test the lights to see if they work, check the loads they're drawing and so on. I'm mostly concerned about service life, either dangerously high transformer temps or drastically reduced bulb life. These lights will be high enough to be quite difficult to access, so changing bulbs monthly is out of the question.
Thanks all,
Jeremy
Thanks all,
Jeremy
