Hi Cal,
Peter suggested five turns of the wire that feeds the motor wound on a piece of iron pipe. That's probably close enough for our purposes.
- Leigh
Hi Cal,This information for a large DC drive.
It is interesting that the page shows an R/C device rather than an L/C system
Line filters are generally between the AC supply and the VFD, either in series or in shunt to ground, depending on the intended function. While it's possible to put a similar device between the VFD and the motor, these are used for very different reasons and in special situations, not related to the current discussion.The device (AB 160) has the description "Line Filter", but the wiring scheme shows input L1, L2, and L3, along with outputs to the VFD as T1, T2, and T3. (series wired) One would think the load power might pass through the device, but it does not have to be.
A device with a closed magnetic path (i.e. a toroid) will exhibit significantly greater inductance for a particular pipe size and number of turns than a simple straight pipe. You'll have an inductor in either case. All plumbing components must be iron, not copper or brass.Does your "plumbers puzzle" need to close the circle in order to function as an inductor? I was thinking all three lines (or two as the case may be) wraped around a straight section of pipe might be the trick. No moving parts either ;-))
You won't see any transients with a clamp-on ammeter.I'm gonna throw the amp clamp on the feed lines to the VFD as well. During "bench testing" I could not detect ANY inrush related indications. The VFD initiates at zero frequency (well 6 hz on one machine, I need to re-program that drive!)
Notice
