DKA65
- Nov 10, 2010
- Houston, TX
Hey all. I am new to the forums and found my way over here through a couple different sites as I was searching for answers. I am reading everything I can find and will continue reading through this forum but I have to get some info and ask a few questions as I do this.
I have a Champion VR-10-12 Compressor. It has a 120 gal tank, with what they are calling a 10HP pump (it is an R30-A), and a Dayton 2N979 10 HP 3 Phase motor in a 215T frame.
The compressor will run on a 7.5 or 10 HP motor. Right now I have to find out if the 10 HP motor is even good.
I only have single phase coming into my property and think that a phase converter might be the best way to go. I was thinking of building or buying a static phase converter and adding an idler onto it.
If I end up using a 7.5 would a 15 HP motor work and with the 10 hp would a 20 hp work or would I have to go larger?
Also, is anyone in or around the Houston, TX area that knows of a scrapyard or recycling center that I could pick some stuff up at?
