I have a 15 HP rotary converter for a lathe with a 7.5 HP motor. The lathe has push button motor start - 2 buttons, slow and fast for the motor. Starts very well on slow but I am limited to about 380 rpm ( it's a 17 inch lathe - in the UK ). The lathe is capable of double that on 'fast' motor speed. If I start up using the fast button It seems to overload the boost light which flickers and chatters. Starting in slow and then hitting the fast button does nothing. I would have thought the power of the converter would handle it.I know almost nothing about 3 phase. The converter was professionally installed to the shop and has a 60 amp supply as specified. The converter info is here
http://www.powercapacitors.co.uk/wp...erter_installation_operating_instructions.pdf
