NC Rick
- Oct 7, 2007
- Asheville, NC
Hi Folks,
I am in need of a bigger lathe in our shop. power here is limited to 220v single phase (100 a max). When I installed our Phase 1 Bridgeport vert mil (2hp), I used a Teco (Westinghouse) VFD with wonderful results. My problem now is that I have located a Southbend Nordic 15 that would be perfect for my needs but it has 5 HP motor (from the owners manual information) and I have seen other info (on the web) that indicates that the motor could be a 7.5hp.
So far, I have been unable to find a VFD that will drive the 5hp 3 phase motor with a 220 v single phase input. I doubt I will ever need all the HP (I need the spindle through-hole diameter).
Are there VFDs available to meet this need? Is there a better alternative? I do not need the variable speed for the gear head lathe.
Thank you for any guidance in this matter. Happy new year!
Rick
Asheville, NC
Rick
Asheville, NC
