beansdiesel
- Dec 5, 2013
- Woodbury, TN
I have a 80hp RPC that I got a couple years ago when I bought out another company. I have not needed it until now, I am getting a new Doosan lathe in next week and since I already have this RPC I want to try and use it.
Already know I will have to start it with a pony.
My 400amp service is split into 2 200amp breaker boxes and is probably 50' of wire length away from my machine/ machine room.
The Doosan specs for power requirements is 72.95 amps at full capacity. It is a LSYC lathe so 20hp main, 5.5hp sub and 5hp rotary.
I attached the specs plate pic off the RPC, but it is rated 13.6 Idle amps.
So, not sure how to wire this beast up!
The RPC I want to be right next to the main service panel boxes. Keeps the distance down for wire as well as having to hear it from my machine room.
Not sure of the best way to wire it into my dual 200amp breakers/boxes. What size breaker it will need in the single phase side. How many amps total should I anticipate the system using with the RPC and machine combined? After the PC, should I run to a disconnect box in my machine room? In the future I plan to get a bigger mill and run off this PC as well, but thats a few months off probably.
Thanks for any help!
