Boat Dog
- Aug 11, 2011
- Middlesex MA
I am sure there is information on this somewhere but I'm not sure on the specifics. So here is my question.
I just picked up a Hardinge HLV-H lathe that is setup for 440 V 3 PH. I have a 20 HP RPC that feeds my three phase panel with the maufactured 3rd PH at 220v or just under. What is the best way to get power at the correct voltage and Amp to this lathe.
I heard that I could come right off the single phase panel into a single phase 240/480 step up transformer then into a VSD with a 3 PH output, but this may be a problem with the 2 speed motor. Another option would be to use a 3 PH 240/480 stepup transformer after the 220 3 PH panel and go directly into the lathe. This will power all the motors (coolant,varidrive,feed) and allow switching speeds and reverse without any problems, you just need to make sure the manufactured leg is on the correct motor starting leg.
Any suggetions or comments, also a little confused over 240/480 stepup transformers when I have 220 volt at the panel and the machine is looking for 440V.
