conant
Stainless
- May 13, 2013
- Shasta County, Ca. USA
I will make this as simple as I can. I have an Anderson 7 1/2 hp RPC. I use it to run an older 40s lathe with a 7 1/2 hp motor,huge compared to the RPC motor. It starts the motor fine within a few seconds of bringing it to speed.
Before I start the lathe motor, the RPC is somewhat noisy,almost annoying. Start the lathe and it is smooth and quiet. Very pleasant.
I recently got my Bridgeport with a 1 1/2 hp motor, back together and wired in. I started the RPC, then the Bridgeport motor and the RPC didn't quiet down a bit. The RPC is located about 5 feet away from the mill, so that doesn't help any.
I was at a point of either running off single phase to a static Phase a Matic, which the previous owner used, or going VFD.
Today I decided to start the lathe motor first, like an idler, and try the Bridgeport. What a difference. It starts the BP motor and the RPC runs very quiet.
I have read that the additional motor on the first machine started is a boost to the RPC.
I am not fully certain that this is entirely the case. All I know is once the lathe motor is running, the shop sure is a lot quieter. The lathe has a clutch by the way.
Without the lathe motor running, the RPC seems like it takes more of a load when starting the BP motor. It sounds that way anyhow. With the lathe motor on the BP motor starts with barely hearing any start up load on the RPC.
Is this typical, and am I good to go running like this?
