katou
- Oct 4, 2006
- Toronto, Ont.
Hi, this is the lathe that I am considering purchasing for $600:
Used Machines - Lathes / SV 18 R | Fermat machinery
For those without the inclination, here's the specs:
Machine: SV 18 R
Producer: Tos
Year: 1950
Base parameters Swing over bed : 14.5"
Distance between centres : 48"
Swing over cross slide : 8" mm
Main motor output : 9hp
Dimensions: 36" x 100"
Machine weight : 4000 lbs
It appears to be set up with a 3phase motor. It is a much bigger lathe than I would normally consider, but the price!
It has some accessories, follow rest, bunch of drills, but no 4-jaw.
I'm considering it, even though it will be a bit of a squeeze into my shop.
The weight is a bit of a problem too, but it seems like a pretty cheap way to get into a home machining setup.
So, the question is this: This machine requires a phase converter sufficient to run a 9hp (nameplate) motor, how much of a pain is it going to be to set up a converter? Is it worth the effort?
This may tip the scales over to "no thanks" but I'm not quite sure. I do not have any other 3phase equipment at this time.
Thanks for the help,
Katou
Machine: SV 18 R
Producer: Tos
Year: 1950
Katou
