The subject of "compensated" transformers, where the turns ratio is 'adjusted" to make up for losses has come up from time to time.... usually when a question about running a transformer in reverse is concerned.
We found some..... Hammond Power Solutions "Spartan" series are definitely compensated..... we found that they came up 5% to 7% short when run in reverse..... we wanted a 120 to 416v and it came up around 390 VAC output..... The turns ratio is a bit short, and we could not use them where we wanted. This was in a few hundred VA unit, 250 or 500 VA IIRC.
Naturally, if run FROM 416V, it will come out a bit higher than 120V at no load, and drop presumably to 120V, under load.
So, yes, they DO exist.
